Plugin: Note Link System
Can he add links to each line of text, as demonstrated in my video. :face_holding_back_tears:
@ylc395 Did you plan to work again on this plugin
I am not sure if this is maintained or not, but one thing I noticed and worries me a bit is that when you have a link to a file on the Internet in the note, the "hover to preview" feature actually pop-ups the "save dialog" for the file, which I see as a potential security risk.
This plugin is very good, thank you very much.
I would like to know if it is possible to modify the automatic header "Backlink". I don't mean the word but the format (h1, h2, etc.).
Also, it appears differently in different notes. Does that have any meaning?
I am using only the automatic mode.
Any suggestions?
Thanks.
Joplin 2.8.8 (prod, win32)
ID del Cliente: eee54006aa794fecb8a1c84835a1ee59
Versión de la Sincronización: 3
Versión del Perfil: 41
Llavero Soportado: Sí
Revisión: c2a6a13
@ylc395
thanks for your great plugin. Really what I searched for and needed. :grinning:
Especially for the enhanced Quick Link functionallity, to be able to link in a note
further to choose one of the headings elements OR the id (for text to make it as link target).
That comes near to Obsidian functions and is very helpfull for cross reference links!
One question:
In the "main-feature-5-set-id-for-text-to-make-it-as-link-target" I noticed that the text
in the brackets: {id-of-element} only works with lower case letters. Is that right?
Otherwise the link reference goes to the top of the page.
But of all: Well done! :tada:
Greetings
tuxfanmatze
from Hamburg, Germany
Client-ID: dba7a74f3e304ef1a1e9b78a691e893d
Sync-Version: 3
Profil-Version: 41
Revision: c2a6a13
Snipaste_2022-11-17_21-12-57
:grinning:Hello, thank you very much for developing this plug-in!
I have a suggestion, I would like to have the option to unshow these ICONS, it would be great if you could
I found that, upper case letters works. While the id does not support ‘.’ within or it will jump to the top of the page. Also, when the id's first character is not English letter, the preview goes to the top of the page.
Hi @ylc395,
As I reference a lot of websites in my notes, I find that I keep on having to use the Ctrl + K shortcut to paste in the link and the webpage title. Is it possible to have some way to prompt the user if they would like to convert the link they just pasted into Markdown format? More specifically it would identify URLs and fetch the page title to put it in Markdown format.
Example
What is typed: Plugin: Note Link System
What it is converted to: Plugin: Note Link System
Since the Note Link System already uses a Previewer, it should hopefully be straightforward to implement.
There is a plugin that does this called Edge Link MD: When pasting URL copied from Edge address bar, convert it to a Markdown link, but that only works for Microsoft Edge as they have a special clipboard format named Link Format.
I have already created a Github issue here. Would also be glad to hear from others what they think of this proposed feature.
Hi Great plugin! As I was going through it, I noticed it kinda fork/copies/includes some features from another plugin. Specifically, the Quick link and copy anchor link features that I use every day. But right now seem are not working, at least relate to these features. Some time ago. I have read in this forum discussion about Quick link (Quick Links Plugin - #143 by roman_r_m) mentioning an update to Quick link plugin due to Joplin switching/update to Code Mirror 6. So, I reinstalled the Quick link plugin and Copy Anchor Link to get these functionalities back, since yours doesn't cover it anymore, at least in my desktop. I'm not entirely sure if I got it right, though. Does Note link system share the same issue as Quick link in the past, or is it running smoothly without any problems? Could the issue I'm experiencing be caused by something else? Thanks a lot.
This plugin is a time saver. However, it seems I can only preview the url linked content when I'm in the two-pane mode (markdown and preview), but not in the single wysiwyg view. Is there a way to make it work?
The great and essential quick link feature stopped working in the new beta version of joplin (with notice that quick linking is not compatible with the new editor). Will there be an update? Thanks for the great work
I sincerely hope that you will update this plug -in. Thanks!
The "Note Link System" plugin's feature called "Quick Link" stopped working in one of the previous releases due to the CodeMirror v6 upgrade.
This plugin is specifically mentioned as lacking support in one of the Joplin config files which probably causes code related to auto-completion to be ignored.
I suggest leaving this plugin enabled for the following features that are still working:
  • Quick Copy Element URL
  • Referrers
  • Preview local/remote URL (seems to be not working too)
  • Show website icon for URL
Now talking about the "Quick Link" feature that stopped working, also enable the "Quick Links" plugin until this one supports the new engine.
It allows you to easily include a link to a note by typing "@@", but it doesn't allow you to choose a specific section of the note (anchor/header). Here is a feature request for it.
Now if you still wish to easily link specific section of the note here are 2 options:
  • in view-only side look for your header and click on # symbol - this will copy the URL you can paste;
  • type "@@" and select your note, but then append #name-of-header to the generated link.
is thst still working.
All what I get on my side, when I press the button is this
There are only default placeholders but not a specific ID.
It addition it looks like I have to add ID to block at first, before I can mark an element.
Copying the ID as mentioned here
contains only the Node ID:
or do I need to fiddle around with html as suggest in Can Anchors Link Within A Single Note??
I tried this but it always gave an error of failure to fetch.
yes, it completely stopped working. at least it shows the icons sometimes.
I've noticed scroll-related issues in the latest Joplin pre-release without the Note Link System plugin installed. I'm linking to the relevant GitHub issue:
@personalizedrefriger thanks for referencing this.
I'm actually sorry for blaming the Note Link System here.
My bet is it's Rich Markdown plugin - explanation here.
But at the same time, looks like you were able to reproduce it even without all plugins. Interesting...
@ylc395 This is such a fantastic plugin, I sincerely hope that you pick it up again. I absolutely love how I can expand referrers and see additional context from the block where the original link exists. It would be great if you could get the quick link portion working again, I know we can use that plugin separate from this one, but having everything consolidated in one plugin as before would be fantastic. Anyway, super awesome plugin, really hope you’re able to continue development on it at some point.
@@ is not working anymore on v3.14.12 windows version.
