Hi, I love to work with Joplin. But sometimes it would be great to have two or more notes open at the same time. So that you can switch easily to different contents.
Is there a way to open a note in a new view, like a tab or something?
Regards Jörg
Regards Jörg
If you like joplin's built-in editor, please use: Plugin: Note Tabs
Otherwise, you can see how to open the note with an external editor
@rxliuli Thank you. That will help a lot.
