Constantly throttled by OneDrive, cannot sync at all on fresh device
OneDrive
I am trying to sync on a new PC (from scratch) from OneDrive.
My archive is made up by about 13k items.
For the first time ever (did not happen in the past, I am user of Joplin for 4 years) I am constantly being throttled (as written in the logs).
Since two days I am trying to get the client synced but sync never reaches the end.
In the log I see Joplin sleeps for some minutes after receiving "throttled" message, but apparently it is no longer long enough.
After the pause, OneDrive lets download some more items but, in the end, it returns an HTML page "Sharepoint error".
I tried changing the concurrent connections from 5 to 1, to 20. Nothing helps.
Some thoughts:
  1. Maybe sync should pause for longer when detecting a "throttled error"? Is there any way to set this pause time?
  2. Maybe sync should make requests slower?
  3. Maybe sync should continue since where it was left with the problem instead of restarting from the beginnning?
So now I am stuck in a endless loop, cannot sync any new device.
I know exporting/importing is not a solution because it leads to dupllcated notes.
Maybe I can copy the whole Joplin folder (containing the sqllite db) on the new device? Could it work or has some identifiers of the device and it would do a mess?
Thank you in advance for your help!
Is it helping ?
Thank you for your answer.
I already started sync from a clean state by uninstalling Joplin completely and removing the data folder. Unfortunately it does not help.
Indeed, it looks like the problem is strictly on the sync process and its timings.
Looking at the code, it suggests the amount of time to pause is taken from the amount of time instructed to wait by the api itself, so I wouldn't think there is anything that can be done better in that regard
I'd suggest setting the value to 1 and then waiting a few hours before you attempt to sync again, because the throttling may take some time reset itself. Other than that I don't think there is anything you can do to avoid the throttling when syncing a new device from scratch, other than to use an alternate sync target to OneDrive, if your note collection is getting too big to work well with it.
If both old and new client are both Joplin desktop clients, there should be no issue to copy this to a new pc, so long as you don't merge the folder with an existing Joplin folder on the new pc, but delete any existing folder before you put the new one in its place.
I think what the software needs is the ability to use a specific client ID and Secret when connecting to the Google Drive. Using the Google Drive API through the secret and client ID will improve performance dramatically.
I use an open source app to mount my Google Drive with a client ID and Secret so the software can use the Google Drive API and it doubles the performance.
Joplin's OneDrive connector is not providing the option to enter the client ID and Secret.
I think Joplin already does use client id and secret to call the OneDrive api. It will obtain and store them when you login using oauth:
We would all have needed to launch the azure site and Link it to a new client ID and Secret that you put into the app only there is no place to enter this information when setting up OneDrive in the software. Perhaps there's a way to manually add it by editing a file I don't know. The software is using a shared client ID and Secret with perhaps thousands of other users which is why you want to have your own personal unique client ID and Secret which is not in the documentation and I don't think it's implemented.
Please, somebody correct me if I'm wrong.
The reason that I'm suspecting that this is a requirement is that I use another app called rclone which can either use the shared client ID or have its own client ID and the speed doubles when you set up your own client ID.
For example when you install Joplin and set up the OneDrive sync is that process offer you the opportunity to enter your own client ID and Secret and did you create an ID and secret?
The only way to create your own client ID in secret is to use Microsoft Azure Which requires that you log in with a Microsoft account And Give them your information to set up an account And then you can create your own ID and secret.
UPDATE
I asked one of the AI search engines about using your own client ID and Secret and it said that you can when you set up your OneDrive synchronization there is an option to click on advanced settings and that's where you put in the client ID and Secret. If you've already created your OneDrive sync like I have there might be a way to add it in afterwards only I don't know where it would go. Probably need to back up data and recreate the synchronization for OneDrive and choose Advanced options.
Now you’re using your own OneDrive API credentials instead of Joplin’s default ones! This is useful for higher reliability and avoiding rate limits!!!
There's definitely not an option to do that within the Joplin UI. Is that referring to the OneDrive oauth screen that you get a link to in order to authenticate? I just tried this and could not find any such option for advanced options throughout the login journey.
Are you sure this is possible with a free Microsoft account? It sounds like something which you might need a Microsoft Azure subscription for
I'm not 100% sure where in Joplin you can add the information but I'm going to investigate this further.
You have me curious about boosting the performance even though personally I don't really need it because I don't upload and download amounts of data that would really make a difference.
Approximately how much data do you move up and down to the OneDrive on a regular basis? That would determine whether or not you're getting full results because of the shared default client ID.
YES. I needed to create a Microsoft Azure account and give it all my information including a credit card which was not charged anything because I'm not using anything in Azure that cost anything and they give you $200 in credit to start with anyway. It is totally free but you do have to create an account and set up a phone number and credit card and then you have the option to create your own client ID and Secret.
Like I said I got the instructions from AI so they may not be correct. I did find an option to edit the json file and manually add the client ID and Secret but I haven't tried it yet.
I'm going to post a question in the Joplin forum about setting your own client ID and Secret when configuring the OneDrive synchronization and see if one of the support Personnel or Developers sees it and has an answer.
I'm going to continue to research this with the internet and other search engines.
Now that I know it might be possible I want to do it because I do have the client ID and secret and azure setup for myself.
I dug a bit further and found the client id and secret is hardcoded in the source code here:
There doesn't look to be any way to change them without modifying the source code.
That is why I decided that I'm going to post this specific question to The Forum and see if I get an answer that we can both use.
Thank you for checking the source code and finding this information it's helpful as a start.
That has to be the default Joplin ID and secret because I have my own that I want to put in there from my Azure account.
Have you considered trying the s3 sync target? It might have better performance than onedrive, and there wouldn't be any kind of shared client ID or throttling
I've been using it with Cloudflare R2 (which has a very generous free tier, you only need to pay if you exceed 10gb storage/1 million class A and/or 10 million class B operations per month)
Personally, I don't do a lot of uploading and downloading and the throttling doesn't bother me at all or affect my work. I would just like to help someone who is having trouble with throttling. I would like to have it available for me as well if it's possible I already pay for my OneDrive storage so I don't need to open a new account with an S3 provider.
What's the open source app you use? Does it run on MacOS? Google Drive isn't updated for my Catalina system, running an old version. If they change authentication, I'll have to switch to rclone to access files on that system.
When OneDrive had their outage a couple months ago, I switched to Joplin's own cloud service for synchronization. It's been rock solid.
I use rclone. It's compatible with Windows Mac and Linux.
You'll want to create a client ID and Secret.
Google has a procedure for creating the client ID and secret and Microsoft has a different one. Which platform are you interested in?
I can give you some tips on how to configure it.
I'm actually putting together a video tutorial for how to create the Google client ID and Secret. It can be a little tricky. It should be ready in a couple to three days.
You can use the shared client ID and secret but it's a lot slower because it gets throttled more.
Thanks. I'm all setup with rclone. It's a great tool. I've mostly been using it for OneDrive, but it's also set up for Google Drive.
After waiting 48 hours to "reset" throttling thresholds, I set concurrent connections to 1 and retried to sync.
This time I never got throttled (looking at the log).
Nevertheless, sync is impossible and won't reach the end. I am stucked.
So the problem is not because of throttling but due to something else.
Looking thoroughly in the log, I can spot the usual problem: sometimes I receive an HTML error page instead of the JSON markdown file.
What I do not understand is that I see multiple errors in the log with "retrying (0)" or "retrying (1)", but in the end synchronization is not completed.
Maybe I can attach a log for someone willing to understand?
Here is the final output on UI:
I have about 13k elements, so sync is not complete at all.
In rclone there is a feature that can help with a slow throttle connection. By default when you do a config of a remote it asks you for a client ID and a secret and you're allowed to leave them blank and when you do you're using the universally shared client ID and secret that is used by everybody else and when you connect to the server you're coming there with the same client ID as everybody else which is why it's a problem.
I know how to and have created my own client ID and secret on both Google and Microsoft. That makes the connection a lot faster and reduces throttling and if you're not using a personal ID and secret you should consider that because it can help with the transfer and throughput of your data to and from the server. This may correct some of those odd errors that you're getting.
Additionally, in our clone do you have cashing enabled because that's also important.
Put this on the command line with the mount command.
--vfs-cache-mode full
Give those two things a try see if it helps I think it will.
When I run a file copy test with a dedicated copy app I get double the speed with a client ID versus the shared client ID.
