Sync problem
OneDrive
I do not know what to do in response to this Sync message - Quote "Last error - Fail Safe: Sync was interrupted because 100% of the data (1256 items) is about to be deleted. To overcome this behaviour disable the fail-safe in the sync settings" End Quote. Comment - What does it mean to "Disable" Turn it on (as it is now) or Off" ? Clearly I don't want to lose my data HELP!! (and thankyou )
I'd suggest exporting everything as a JEX file, then let it delete everything, and reimport the JEX file. Then you'll be in sync with the sync target.
Many thanks.... I'll give it a try
