Best way to handle "contextual to-do lists"?
Joplin 2.14.19 (prod, linux)
Client ID: 21e0babef7f2402fa0480a3ce8ba9bd1
Profile Version: 46
Keychain Supported: No
Revision: 971c4e5
Backup: 1.4.0
Metis: 0.1.5
I'm used to collating together "ToDo-style items" (ie things that I'll eventually check off) into contextual documents (ie being in a specific place, with a specific person, ...), with one document per context.
Those documents tend to get fairly deep for me - I'm used to handling priorities by ordering those, having sections with sub-headings etc.
(I've previously been doing this mostly in Google Keep and have some migration material from there, as well.)
From Google Keep, I find the feature that moves checked items out of the way to the bottom of the document absolutely invaluable: I get to keep a record of past items that, and unless I specifically scroll down there, those basically completely stay out of the way of adding new, organizing, going through and checking off 'active' items.
I can't seem to find / it doesn't seem to be possible to have that kind of functionality in Joplin...? I've also had a look around the plugins, but didn't readily find anything that would seem to match this.
I've seen the various to-do related options in the view menu, but they only seem to affect "one note as one to-do within a hierarchy of notebooks"; it doesn't seem to affect anything within a single note/document at all. I specifically feel that the "one note per item in a hierarchy of notebooks" to-do paradigm does not adequately allow me to work the way I want; also, it would create an interop/migration issue for me (since relevant information would not be within the marked-down document, but elsewhere).
Is something like that already available, and I'm just not finding it? Or should I be looking into implementing a Plugin that takes care of this.?
Check out this post which includes CSS that moves completed to-dos to the end of the desktop note viewer.
For a cross-platform solution not requiring the note viewer, manually sort selected to-do lines if needed (with the instructions below), then move completed to-do lines to the bottom (with End and Enter).
If neither of the above work for you, check out different ways to manage your to-dos as described here (and elsewhere in the forum): Tasks as in Evernote
