I was thinking that instead of using a clipboard manager app that handles both short-term and long-term clips, I could use Windows for the short-term (history) and Joplin for the long-term.
It's easy enough to create a Clips notebook with sub-notebooks for categories of clips, with each note under them acting as a clip. But I'm wondering - is there a quick way to copy a whole note to the clipboard while in the note list? That would be easier than going into the note (clip), selecting all (ctrl-A), then copying (ctrl-C).
