Unable to sync after rebuild
Joplin 3.3.13 (prod, linux)
Device: linux, 12th Gen Intel(R) Core(TM) i7-1260P
Client ID: 20811f6ea6984e769b17c517dac4b5c8
Keychain Supported: No
Alternative instance ID: -
Revision: 144ed59
Backup: 1.4.3
Freehand Drawing: 3.0.1
Joplin Cloud
Unable to sync.
Joplin reports "invalid master password" when attempting to re-sync after operating system re-install.
I store the key in a password manager, so I'm not sure how this can be an issue.
My Android phone is still able to sync; is there anyway I can compare the master password it is using?
I suggest you create a new profile on your linux desktop, and sync it to your joplin cloud account from scratch.
Useful guide for sync issues: How to fix synchronisation issues and start over
Thanks very much for the response.
I was using an outdated key; issue is now resolved.
