To report a bug, please let us know:
iOS 13.3
macOS 10.15.3
Joplin 1.0.175 (prod, darwin)
Joplin iOS 10.0.40
Firstly, how do I change the cloud provider? In Joplin Preferences on the Mac the section “Synchronization” doesn’t seem to open into a Dropbox (currently using OneDrive) login screen after clicking “Apply”.
For a long time I have not been able to use the iOS app, what I mean is I sync the Mac client with the cloud provider, then I set up the iOS App and sync the data with it. Then I change and edit Notebooks, and Notes on the Mac App, and then sync them with the cloud server. I then try to sync the iOS app in order for the changes to appear but what I get is no change, and hundreds of notes not decrypted. I have uninstalled and reinstalled both Apps but this doesn’t appear to help.
Any help or suggestions are welcomed and appreciated.
