Small quality of life improvements to Joplin
I am a very, very happy user of Joplin! I use it all the time to organize mostly code snippets and work instructions for my projects. So if nothing happens with these, no hard feelings! Still I keep stepping on those same little rocks in my shoe and I thought I'd write them down here:
1 Copying a line of inline code shouldn't copy its surrounding formatting code. I you select the line of code without being super precise, you'll get on your clipboard something like:
'npm i ...'
&nbsp ;
2 There used to be a markdown editor. Now i can toggle editors but I have no idea what it's for. There is no markdown anymore to be edited.
3 There is no warning when dragging a note to another parent. This can happen very easily without even noticing it. Just a popup with the message: "Do you want to copy A to B?" with Ok and Cancel button would save a lot of head-scratching 'where the hell is my note?!'
4 Clearly marked "Search all" button and show search scope when using it.
5 There is no File, Open option. I actually don't really know where my notebook is stored. Could also just be an Info option under Notebook in the menu that shows the path. I don't couldn't find the path in the menu options anywhere.
6 I always reload a note to see that it recognized and converted links. This should just happen when the link is pasted, or space or return key is hit.
7 Language selector dropdown when adding code blocks. It does work well already but I tend to use the same languages so it would be nice to pre select my common ones with an option for 'other' to specify another language.
Answering what I can below:
2.) See WYSIWYG Toggle for how to toggle between Markdown and Rich Text editors.
3.) Changing notebook appearance when dragged over may be more helpful. Another option is pressing Ctrl+Shift+P then using moveToFolder to type or select a notebook.
4.) Search plugins like VS-Code Style Note Search show search scope.
5.) The first line of Tools > Options > General shows full path of where notes and settings are stored.
7.) Workarounds include prototyping that with the Slash Commands plugin or using a text expander.
That's because you shouldn't really be messing with those. They aren't meant to be edited by the user.
3: Yes I think this isn't handled very well, but I don't think a Popup would be necessary the best UX. At least for the Desktop version:
There is no Animation, Highlighting and other visual Feedback, which imho would be the proper way to solver this. I think an optional Popup could be viable, too: "Hey want to move this Note to X? Yes, No, Don't ask me again". Users who use Drag and Drop a lot could disable it. Another Option could be to show a short Notification somewhere "Copied Note X to Y", this way Users can quickly find the note again. The other alternative is to disable Drag and Drop, if not implementing a proper UX? However not sure how this is implemented in Mobile.
4: Agree. Using a Plugin feels like a workaround, I think either displaying the context or highlighting it in the sidebar could be a possibility.
5: Besides the already mentioned way: Help > Open profile directory
7: You have a drop-down? I mostly use the richtext editor, while I like Markdown I also like rendered links, images, tables, etc. and I don't saw any Drop-down there. Which may relate to 2, having two editors with different capabilities is somewhat confusing.
