Right procedure to sync multiple client
I was wondering which is the right procedure to have 2 Computer synced with same NextCloud source.
I have 1 installation synced with my nextcloud with 70roughtly notes:
  • if I configure the second one to that nextcloud folder, the folder is emptied.
  • if I import the folder as raw before hit sync the data will get duplicated (files in the folder becomes more than 100).
Please help!
Thanks
You might want to delete your local data on both computers and start over clean. Also see the faq https://joplinapp.org/faq/#all-my-notes-got-deleted-after-changing-the-webdav-url-
Thanks,
It worked.
In the faqs there isn’t a reference about it, maybe should be added.
Regards
