How to Sync Joplin with Nextcloud on Multiple Devices?
Hello guys! :wave:
I have been using Joplin for a while now and I truly like it. I recently set up Nextcloud to sync my notes across several devices. The original sync went flawlessly on my PC but I am having difficulties getting it to sync correctly on my phone and tablet.
I performed the identical setup procedure on each device, however it appears that the notes are not updating consistently. Sometimes the adjustments I make on one device do not appear on the others. I am not sure if I skipped a step or if there's anything special I need to do.
Has anyone else ran across this problem? I had welcome any help or recommendations on how to make the sync operate seamlessly across all of my devices.
I also check this: https://discourse.joplinapp.org/t/problem-syncing-in-multiple-devices-and-nextclouqlik But I have not found any solution. Could anyone suggest the best idea for this?
Thanks in advance!
Respected community member! :smiling_face_with_three_hearts:
When you are done with edits on the phone/tablet, do you sync those changes back to the server?
Do you have any conflict notes on the devices?
