Syncing with Nextcloud using webdav
Can I have more than one webdav address?
How do I generate it?
Do I need more than one, if I do use more than one Joplin profile?
I have the problem that I got notes from one profile synced into the other
If using nextcloud or webdav you just need to make a new folder and give Joplin that as its sync target.
So my main Joplin profile might be:
https://mynextcloud.com/nextcloud/remote.php/dav/files/me/Joplin
But then I might have a separate Joplin profile called "work" so I would make a Joplin_Work dir inside by Nextcloud that this "work" profile uses to sync.
https://mynextcloud.com/nextcloud/remote.php/dav/files/me/Joplin_Work
Thx Mate perfect. It was quite simple.
I did do an .jex export. And import it again after crating a new profile and a new sync target folder for it?
So before I had all my Joplin notes synced with https://myserver/remote.php/webdav now it is https://myserver/remote.php/webdav/files/joplin_work
