I cannot open access that menu
My Joplin has become unusable, for some reason. I suspect it might not be Joplin's fault, but maybe you can still help me?
Starting today, when I open the program, there is some sort of rendering problem which makes the program unusable, as better shown in the print screen (I added boxes over the notes list for privacy reasons, but the remainder of the image is exactly how it shows to me).
- I cannot move or minimize the window.
- I can still write in the writing area.
- I cannot close Joplin. Alt F4 does not work.
- I cannot change to any other window (alt tab), because Joplin's stays in the front and prevents me from doing anything else. I have to hard reset the computer because I can't use it anymore after starting Joplin.
- Using tab, I can "jump" to Joplin's head menu, but I cannot open the submenus.
- The cursor is shown at a much higher place in the screen than what Joplin is considering it to be (I can tell by the "shade" that changes in some places, as if the cursor were over them).
I'm using Linux Mint 21.3 Mate, using the software management program which comes with it, which uses flatpak's version of Joplin. I tried to download the appimage directly from the Joplin website, and it has the same problem. Made a new installation via terminal, as recommended in Joplin's website, but it's the same. I even tried v3.1.4 (pre-release), and it also has the same problem.
Thank you!
