Reference external folders and files in a Joplin note
Simply drag and drop the file/folder into a note with pressed 'Alt' key, than a reference/link is created in the note instead of a copy.
Found this method (here), tested it on my windows system and thougt WOW! :blush:
So I left a :heart: for the source post and repeat it here to spread it to everyone again...even if everybody except me knew it already :wink:
Useful tip, thanks!
Interesting that this behaviour adds newline chars (2 before, 3 after) around the created reference. Adding such newlines is identical to when a file is Attached, whether by drag-drop or menu (Edit -> Attach File).
Would be time-saving to be able to disable/customize the addition of newlines. I am deleting them every time I attach/insert actual files or file references.
I agree the new lines addition when dragging/dropping files or references should be optional
This topic was automatically closed 730 days after the last reply. New replies are no longer allowed.
