Issue with drag and drop multiple times
Is this normal... dragging an image onto the markdown window for the Windows 10 desktop version creates an entry in "note attachments" with a unique ID. Doing it over and over again each creates a new unique ID, another "note attachment" entry and bloats the space taken by the notes attachment data. Is this just how things are supposed to work?
Do I need to just add an image once, then copy the initially created link for each note I want to show the image on? I've been doing this but it is very tedious.
Is there a tool or a plugin that can clean this up?
is there a plugin or a way to have the inserted image compared to the database and just insert the existing ID in the document IF the images are identical?
Is this a bug, a feature or did I just make up a wish list item?
Joplin 2.9.17 (prod, win32)
Client ID: e33a656317c54dcea10be27a451197c3
Profile Version: 41
Revision: a84a8e7
