Random notes have check boxes in their title
macOS
Joplin 2.14.20 (prod, darwin)
Client ID: db7d477f077e4dae8c07a45f7913abdc
Profile Version: 46
Revision: cfd98e3
Backup: 1.4.0
OneDrive
Rich Text Editor
I have just installed and begun importing evernotes into joplin. randomly some note titles are showing check boxes - in the list of notes -- (not visible in the title). i have tried cutting, clearing and re pasting the title - no change. any idea now to fix these? note i dont know if i am using rich text editor - can't find it in settings.. only remember a msg about using rich text at the start.
tia
Try right clicking on the note in the list and select "Switch between note and to-do type"
Some of your notes may have been to-do reminders rather than notes.
HI
thanks - coincidentally i just hit select all on this .. and saw that.. that fixes it.. turns out these are ALL notes that had reminders on them from evernote.. ty :slight_smile:
