Check boxes ? not visible
macOS
Joplin 2.14.20 (prod, darwin)
Client ID: db7d477f077e4dae8c07a45f7913abdc
Profile Version: 46
Revision: cfd98e3
Backup: 1.4.0
Rich Markdown: 0.14.1
OneDrive
Rich Text Editor
i have toggled check boxes on and off on a list of items... i use that list usually daily (its a literally a to do list :wink: ). no matter what i get bullet points. i tried installing rich markdown plug in but i don't see any change after that either.
and i changed the note to to-do style (no change)
Are you trying to mix different types of lists? If yes, then that's not supported. You need to divide the different types, e.g. with a horizontal line.
hmm no, its just 1 list in the note. i have also deleted all the regular text from the note - its one big list.. switched to markup and back to rich no change (just found that button lol).
