Checkbox for note name
Joplin 1.7.11 (prod, linux)
Sync Version: 2
Profile Version: 34
Keychain Supported: No
Revision: f560563 (master)
Is there any way to not show a checkbox in front the the note name. It seems to me that it really serves no purpose and I'd like to not see it?
Thanks
Notes have no checkbox, only todos.
The checkbox is to mark the ToDo as done.
grafik
1 = ToDo
2 = Note
1 = create ToDo, 2 = create note
grafik
Thanks, I understand all of that and do appreciate your responses. The issue I have is the I create a todo and in that todo I have a list of things with check box's, I don't need the check box on the title.
I hope that screenshot makes it and that it makes sense.
Just create a note then, it can also contain checkboxes inside.
right-click > Switch between note and to-do type
Great, thanks, that does it. Much appreciated.
