- The version you are using. LATEST VERSION is not a version number!
10.6.2c - The operating system you are using.
IOS 14.3
-If you can also please provide a log, as described here: https://joplinapp.org/debugging
Not sure how to send logs from an iPad or where they are stored
I am syncing via S3 to a Linux Mint 20 instance, Android 11, and an iPad. I had originally did an import from Evernote of ~2,000 notes via markdown. The recent update allowed for me to clear the persistent sync error message at the top of the notes list on Android. There were a handful of errors and I was able to retry them and clear the error message. No such luck on the iPad (per below).
Should I blow the iPad install away and start from scratch?
Is there a way to do "Retry all?"
How can make this error message (which is fairly dominant in the interface), away?
