This error should be fixed with the attached plugin file in the previous reply
I cannot link uploaded Pdf with no metadata in joplin, they dont show up in the search.
I wouldnt consider that a bug though
For some reason I can't install the file under linux. By the way, I always have the same problem with the relative notes under linux. I will investigate.
I will test it in a Linux virtual machine
I have really enjoyed this. Any possible way to add a button to show/hide the side bar quickly?
You can expect it in the next release.
With now an intensive daily use of the plugin some new ideas appear:
- [Inline Todo] : it could be very useful to save some filters that we use often.
- [Inline Todo] : it could be interesting to have a "quick capture" system of todo in the note of the day without having to leave the note while editing.
- [Ergonomy] : I realize that I am always switching from the "todo" tab to the "daily note" tab. It would be great to be able to display the tasks under the calendar
This is just a few ideas for discussion
Everything is already great!
How to hide the sidebar is very important. It occupies a part of the space.
I really, really need this.
The to do plug-in always goes round and round, and it will be better if you restart it. This problem will occur again later.
The vertical space is not enough to merge the calendar and todo lists, especially I need to put the sidebar under the joplin note list on my laptop. But we can show all the todo items in today only under the calendar instead
That would be great already.
Hi @SeptemberHX !
Hope you’re well !
I'd like to make a suggestion for discussion. I find the use of "projects" (+project_name) very convenient. With the recent evolutions of this plugin, I tend to manage all my project documentation in connection with my todos and literature. It seems to me that it could be interesting to have the possibility to set a list of projects in the parameters that would appear in autocomplete even when no todo mentions it. We could even imagine that these projects are recognized with the same syntax in the inline-tags tab (tags::text+project_name) or in the "papers" tab (extract from Zotero for ex.). And even better, a new tab "projects" could show tasks, articles or references related to this project!
Yes let me dream a little
Sound interesting. It sounds more like an aggregator because you can aggregate different items into one tab with custom conditions/filters.
Actually, the next feature I want to implement is the Group
feature, which can treat some notes as a user-defined group. And all the groups can be displayed in the sidebar. (like the vertical layout mode of the note tab plugin but with multiple groups support).
And your ideas can make the Group
feature go further. I will try to implement it when developing the Group
feature. Great thanks for your good ideas!
I just create an issue for this: Feature Request: Group feature that can aggregate todo, notes, papers, etc. into user-defined group · Issue #16 · SeptemberHX/joplin-plugin-bundle · GitHub
Please let me know if you have more suggestions/ideas!
You're welcome . This
group
functionality is great news and it could indeed do that.
In the same way I thought that it might be interesting to have an "info" tab grouping together the metadata of the note. I am thinking in particular of the date of creation, modification, location information (GPS) or whether the note is shared or not, note tags indicating the status (in progress, to be reviewed,), character counter, etc...
For the moment you have integrated a status bar which is already very useful !
V0.5.2 is released:
- All:
- add:
- Dark theme support
- Toggle button & shortcut support to show/hide sidebar
- add:
- Todo:
- add:
- allow to show descriptions for tasks (all the text below tasks with more more indent is treated as tasks' description) #18
- add:
- Papers:
- add:
- new copy markdown link button for annotations
- show paper details for all the papers mentioned in current note
- improve:
- small font in popup dialogs
- fix:
- missing info with book, chapter, preprint, and more #11
- crash when citing some papers with missing information
- cannot sync all items when your items are more than 50 in Zotero
- add:
- Related Notes
- add:
- filters & sorters #15
- jump to the first appearance #15
- add:
Thank you for your development efforts. It’s a great tool !
Thank you for your great work, I like that it now supports dark mode.
Thank you for the plugin. I mainly use it for the outline and todo part. Is there a way to update the part of the todo plugin that you forked to the newest version? With the original inline-todo plugin you get the tags rendered into small blocks in the viewer, which improves readability a lot. For now I'm using both of these plugins at the same time but would love to ditch the original in case it comes to conflicting behaviour. Additionally it would be nice to have the possibility to set the plugin to only show todos of the selected notebook or to have an permanent exclusion list for notebooks (eg. notebooks that contain templates with a lot of checkboxes)
Yes, they are both possible to be implemented. Please refer to the issue page for tracking the progress:
Small bug report, the content of each panel doesn't shift down if you have too much content in the selector:
