sound goods to me. However, I don't think it will be implemented on this plugins. Probably, I will make it on DDDot as a part of the "Backlinks" panel. (e.g Select a backlink, right click, open a menu to remove bidirectional links)
I just rediscover this awesome plugin. I really like the possibility to insert the link at the top of the note, thanks for developing it.
Would it be possible to add a custom text before the links (e.g. "bidirectional link:"), or better two custom prefixes (e.g. "from:" and "to:"). This way, the link that is automatically created in the second note is clearly identified as bidirectional. Instead of being dropped out of context.
Just released a new version with this feature (p.s I will rename to Reserved link prefix on next release) Could you see does it match your expectation? Forward link prefix is a bit trouble and I don't have time to implement it shortly.
Show notebooks - If it is enabled, it will show the notebook of the note (e.g the 5. Archive next to the note title )
Allow new Notes - If it is enabled, it will show New Note and New Task
Select link text after inserting - If it is enabled, it will highlight the note title after inserted. e.g select 2024-07-23 in this link : [2024-07-23](:/xxxx)
Prepend link instead of append - It will insert the reversed link at the beginning of the note instead of the end of the note.
