Notes from nextcloud not synced
Joplin version 2.1.4
Sync with nextcloud
Android 10
i reset my phone and now i tried to restore my notes from my nextcloud to my phone.
I just configured and tested the connection in Joplin app. The connection parameters are good after the tests.
When i sync, everything is fine, no errors, but my folder is still empty and none of my notes stored in my nextcloud are visible in my Joplin app on my phone.
I've use the URL provide in the settings of my Joplin folder in nextcloud.
Tnaks in advance for your help :slight_smile:
Any help ?
Does it sync from your phone to nextcloud? If so, try wiping app data on your phone, rather than reinstalling.
