I am having exactly this same issue. On windows I am using 1.0.45 and on android I am using 1.0.339, database v33.
Please let me know if you found a solution elsewhere. Thanks in advance to Laurent/the forum for any assistance.
Having the same issue with Joplin 1.6.6, database v34 on Android. All of the notes and tags are there and the sync has fully completed, but none of the notebooks are visible. The screen looks like the one in the initial post above. Any suggestions/solutions?
me too. can see all notes (sans images. that's another issue as well). sans notebooks. has this issue been fixed yet? the first time i installed it the notebooks were syncing. in an attempt to fix resources/attachments/images not syncing, i cleared data and cache and reinstalled the app, now both notebooks and images do not sync. i'm syncing over synology webdav
