Note imported from Evernote shows images (using HTML), note converted to MD using same image does no
macOS
Joplin 2.13.15 (prod, darwin)
Client ID: caa1132de4484bea9ce6788275502b2f
Profile Version: 44
Revision: 7d2c1c0
OCR: 0.3.2
I imported notes from Evernote and they render correctly, however, they contain unnecessarily complex HTML so I converted one note, as a test to MD. The text renders without problems but none of the images appear. Instead only their text shows (e.g. Birria-3-scaled.jpg.webp). If I click on that text the image shows up in my Preview viewer, not in the note itself. If I check the MD source it shows exactly the same as the HTML <img src="", i.e. [Birria-3-scaled.jpg.webp](:/dc67cec40b1c11873496b48820a8b0ae).
Can anyone advise me on how to make the images appear in the rendered MD (I don't need to see the images in the MD editor).
Many thanks, Rob
Ah, just in case it helps anyone else. I realise that I'd missed out the bang before the square brackets so
Should have read:
![Birria-3-scaled.jpg.webp](:/dc67cec40b1c11873496b48820a8b0ae)
