macOS: stuck on sync for two days
  • The version you are using:
Joplin 2.8.8 (prod, darwin)
Client ID: 74107cfe910f454cb38599fcf0765eb1
Profile Version: 41
Revision: c2a6a13
  • If it is a sync issue, please let us know what you are syncing with:
    Dropbox
  • The operating system you are using:
    macOS Monterey 12.6.1
One of my Macs has been stuck on attempting to sync for two days. I have other Macs, Android devices, and iPhones that sync to the same Dropbox target which are working fine.
Attempting to cancel the sync has no effect - except to display Cancelling... indefinitely.
Safe mode has no effect. Rebooting, etc., no effect.
The only errors I'm seeing in log.txt are a couple sync errors from about a week ago, such as:
Synchronizer: "Error: Cannot acquire sync lock because the following client has an exclusive lock on the sync target: (1 #d2c3e6b09a744b9098fd456d56fc285b)
Code: hasExclusiveLock
    at LockHandler.<anonymous> (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/lib/services/synchronizer/LockHandler.js:202:31)
    at Generator.next (<anonymous>)
    at fulfilled (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/@joplin/lib/services/synchronizer/LockHandler.js:5:58)
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (internal/process/task_queues.js:95:5)"
However I'm not seeing any errors from the past two days, except on loading plugins when I entered safe mode.
In the console (debug mode) I'm seeing a bunch of warnings about updating components like:
Please update the following components: Connect(MainScreenComponent), Connect(MenuBar), Connect(NavigatorComponent), Connect(RootComponent), Provider
/Applications/Joplin…evelopment.js:11494 Warning: componentWillUpdate has been renamed, and is not recommended for use. See https://fb.me/react-async-component-lifecycle-hooks for details.
... which I'm assuming aren't affecting the sync issue.
And two plugin related warnings:
DevTools failed to load source map: Could not parse content for file:///Users/xxx/.config/joplin-desktop/cache/Bishoy.EmailPlugin/ui/style/bootstrap.min.css.map: Unexpected end of JSON input
DevTools failed to load source map: Could not parse content for file:///Applications/Joplin.app/Contents/Resources/app.asar/gui/note-viewer/pluginAssets/mermaid/mermaid.min.js.map: Unexpected end of JSON input
However, entering safe mode and disabling plugins has no effect on the sync issue.
I've been researching how to deal with this sync issue, as the app is content to spin and attempt to sync indefinitely, hours/days at a time, without any warnings, errors, or guidance to the user. I never found anything definitive in the console or logs.
After 5 full days of Joplin not able to complete a sync on one computer, fired it up today and it completed a sync right away. No intervention from me whatsoever - I've been researching but never took any action.
Is there a S.O.P. for dealing with "stuck" sync issues like this? I couldn't find anything definitive in Help/Support, in these forums, on Reddit, etc.
Not being able to sync work notes for 5 days killed my productivity. There's got to be a way to deal with sync issues right? I really don't want to migrate away from Joplin but I can't be down for 5 days again with no idea what to do.
Update: I have not yet updated to today's release, still on 2.8.8
