Jopling 2.8.8.
Links are not clickable in both modes (WYWISIG and markdown) even with linkify enabled! It is also tiring and unproductive having to create automatically links...
Thanks for help!
Jopling 2.8.8.
Thanks for help!
For me links are perfectly clickable. Please provide more information. Which OS are you using? Post an example of a not clickable link or even provide an exported jex note.
Kind regards
Links never worked for me on initial copy/paste. I always have to switch to another note, then switch back to the note with the link in order for it to be generated properly.
