Jumping between in viewer mode
While searching (CMD+F) in viewer mode I see the message:
"Jumping between matches is not available in the viewer"
Is there any plan to support search in Viewer mode in the future?
This is odd since most of the time the user is in viewer mode and not in the editor mode.
Great app by the way- thanks!!!
I imagine it will be done eventually. Joplin used to support searching in the viewer only, and recently switched to editor only. It should be possible in theory, but a viewer specific search will need to be added. If you're looking for a way to get involved in the project, that would be a good first addition!
This is not at all true for me, I almost never look at the viewer. Granted, I don't use more advanced features like mermaid diagrams or katex formulas.
