I assume that the above post is a suggestion to implement this. Still trying to work out what the purpose was of posting a long list of hyperlinks to non-existent pages...
Hope to help, I'm creating a library where you guys can have access to multiple languages ββ\ languages. I created this repository.
Thank you for looking into this, but the website is just plain html built from Markdown, so I'm not sure we can use your library?
I will make an api in json for you to consult the language, my idea.
example in pug
a.fw500(href='/help/') stringHelp
a.fw500(href='/plugins/') stringPlugins
a.fw500(href='/models/') stringModels
a.fw500(href='/templates/') stringTemplates
example pug+express
app.get('/en-US', function (req, res) {
res.render('index', { stringPlugins: 'Plugins', stringHelp: 'Help', stringModels: 'Models', stringTemplates: 'Templates'})
another example
example pug+express
app.get('/pt-BR', function (req, res) {
res.render('index', { stringPlugins: 'Plugins', stringHelp: 'Ajuda', stringModels: 'Modelos', stringTemplates: 'Templates'})
api query sample
- joplin.website.repl.it/pt-BR return { stringPlugins: 'Plugins', stringHelp: 'Ajuda', stringModels: 'Modelos', stringTemplates: 'Templates' }
so,
html built from Markdown | html -> pug -> expressjs -> locate ( pt-BR/en-US ... )
fullcase
// api ip locate jquery
$.get("http://ipinfo.io", function (response) {
window.location.href = "joplin.website.repl.it/en-"+response.country; // en-US
}, "jsonp");
reference
I didn't know the site was generated by markdown, it's easier than you think. A viable alternative is for you to translate to multiple languages the markdown.
example
- pt-BR = pt-BR.md
- en-US = en-US.md
- README.md ( pt-br.md / en-US.md)
-- links readme with locate(pt-BR, en-US)
[pt-BR](locate/pt-br.md)
[en-US](locate/en-US.md)
As I didn't know that the site was not generated by markdown, I thought about the possibility of translating the elements in html to several languages ββusing pug via express.
example
references
I hope to contribute with community Joplin. I apologize to the community if I have done something wrong. I'm excited, with lots of ideas to improve Joplin
There are two ways that I see that can be applied, they are efficient and don't require a lot of work
- Translate the entire markdown site into other languages
- Transform the site into pug-js files (this method I used)
I made some corrections to the text to clarify how the site's internationalization process is
### About
This is an unofficial version of the Joplin app website made with Pug-js, Express-js to support multiple languages, includes a list of plugins, themes and templates as well.
### Reason
This repository aims to provide Joplin with internationalization. That is, people accessed the page in their native language which facilitates the adoption of Joplin app in more places.
### Important warning
The translations were done with Google Translate, the best would be to gather a set of people to correctly translate the parts (string) of the site. For this to be done in the true way, we must use a service for this. The most common is Transifex or Crowdin. These two tools like Pug-js and Express-js are some tools that allow us to reuse html type elements on the website and also enable us to offer multiple language support for the website.
Pug-js is a template engine that can render html. Express-js is a middleware responsible for creating API - Application Programing Interface.
The solution has been tested and designed on leading application hosting services and recent software at no cost (I used the free plan for this) such as Vercel, Heroku, Repl-it and Netlify, to demonstrate that it works, is secure and reliable.
link: https://github.com/xaholo3700/joplin.website
process/route/locate
res.render('index', { message: 'en-US', slide1: 'test' ... }) // json strings html from site
redirect user to locate
}, "jsonp");
- change joplin.website.repl.it/en- to localhost/en if you run localhost
window.location.href = "localhost/en-"+response.country; // en-US
}, "jsonp");
