3rdparty Universal Web Link
Hi all,
I would like to share my project here: IAnyLink - GitHub - benlau/l: App Link to Universal Web Link
Although Joplin supports external app links, these links may not be recognized by other website services or applications. For example, if you paste the link in Notion, Google Keep, etc., it is not clickable, and you can't use it to open a local note in Joplin quickly.
IAnylink is a solution designed to solve this issue. It turns your app link into a regular web link, making it recognizable by other services / application.
Usage:
  1. Copy the external link of your note in Joplin.
  2. Open IAnyLink
  3. Paste the link here.
  4. Press "Copy" to get the web link to your clipboard.
For example:
Screenshot 2023-11-01 at 1.00.57 AM
Then you can put it on any other site or app to click and open the Joplin note.
It is not limited to Joplin app link only. You may use it to create cross-links between different applications.
My use-cases:
  1. Opening a VSCode project from Joplin
  2. Opening a Joplin note from Google Keep (I am keeping my mood board in Google Keep).
This project is still in the prototype stage. Please let me know if you like the service (or simply give it a "like" :slight_smile: ).
  • It is running on my GitHub page. The domain name is not ideal, I may purchase a better domain if there is enough demand.
  • I may develop a Joplin plugin to copy the weblink directly if there is enough demand.
Nice. I will try this as it could make external Joplin links (in different programs) easily accessible.
I tried and it works (Linux Mint, Firefox, Joplin).
If I understand you correctly, you can also prepare a plugin? This would be even better - because users can skip a step in the browser and have higher privacy.
It is glad to hear that.
About the plugin, I have developed a prototype. It is under testing and need to write a few words and capture the screenshot before release.
The plugin released!
  1. Open "Joplin" -> "Settings" -> "Plugin"
  2. Search "Copy Universal Web Linkt"
  3. Press "Install"
  1. Copy the universal web link of your note via the note list context menu.
Remarks: You may enable other web link types in the setting page.
  1. Copy all kinds of universal web links via the tool menu.
Nice.
Maybe you should write something about privacy. My friend's first two questions were: "Is this safe? What information can the website get about me?"
@kacnje
A good question. I am not familiar with the official way to declare the privacy data collection policy... Let me try to explain in a few words and see if it can make you feel safe.
Basically, I only interested in the no. of user and where they come from but not everything that could track an individual user
The converted universal web link simply stores the original link in a format that can be recognized by most applications. The converter software I wrote won't add any user tracking code to the converted link. I will publish the source code on GitHub for inspection.
The Joplin plugin won't track users at all and won't add any tracking information to the converted link.
The IAnyLink service site (IAnyLink) currently does not track anything. But I would like to add a GTM to count the number of users and where they come from.
Security - Deep link attack:
The general security practice for an application to support a deep link forbids creating/updating/deleting any data via the deep link. Joplin follows the rules and only allows opening a note/folder/tag only, making it safe to use.
However, not all applications follow the practice. For those kinds of applications, I would suggest not enabling the "auto-open" feature to prevent potential deep link attacks.
I appreciate your work and explanation.
I'm sure publishing the source code will be an important step forward. As I said, when I told my friend about the plugin, he asked me if your website could get his text in notes.
@kacnje
Done.
The privacy policy
The source code
I reviewed the code of the Joplin plugin - looks good in terms of security.
The backend service called "IAnyLink" - hasn't been reviewed.
Mad respect for @benlau. This is a very useful feature.
Not only does it have keyboard shortcut support, but also backend is already hosted for you.
Bravo :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
If the author suddenly becomes a billionaire and totally understandably stops giving F about the backend hosting - posting (once again) a link here to a JS-based repo that can be hosted by anybody.
IAnyLink: Github
P.S. This one seems to have latest updates, but at the same time plugin uses other repo which is actually deployed, but wasn't updated in a year.
I've opened an issue about it to clarify.
I just released the Joplin Plugin v0.1.2.
The changes:
  • Deprecated the use of base64-encoded URLs and replaced them with a shorter URL format.
  • Allowed the setting of a custom iAnyLink Service URL. (In case you want to run your own service)
@benlau Thank you for your incredible contribution—your work truly elevates the project and inspires the community!
Hi @benlau, Today I realized the menu options for creating web links don't work anymore. Neither the top menu nor the context menu (right-click menu) works. After selecting, e.g., "Copy universal markdown web link", there is nothing to paste later. The only way working today, in my Joplin desk is opening link converter and creating the web link manually. Is there anything I have to do?
Ubuntu 24.04
Joplin 3.3.3 (prod, linux)
Copy Universal Web Link: 0.1.2
Hi @Eduardo
I can reproduce the issue when I upgraded from 3.2.xxx to 3.3.3.
Could you try this version of plugin to see can it fix the problem?
Download the jpl.zip, uncompress it , you will find a joplin-plugin-ianylink.jpl inside the publish folder for installation.
Hi @benlau, After installing the new joplin-plugin-ianylink.jpl, all menu options work as expected and just like before.
Thanks for your prompt fix!
Checking later with Joplin 3.3.4 (prod, linux) also working well
Hi there,
I am here through the referral of @muzak, and thanks to him/her.
While !Anylink web working OK, when I tried to installed the plugin in Joplin desktop, I could not find it, I did not see related words from the development of this thread, so, I figured maybe I missed something, any advice?
Sorry, there has a typo in my original message. It should be "Copy Universal Web Link".
