Joplin window does not auto adjust to include elements on the right side of the window
Joplin 1.8.1 (prod, darwin)
MacOS 11.2.3 (20D91)
When I open Joplin as part of the screen (same on internal or external screen of MacBook) (telling via Keyboard Maestro to occupy certain part of the screen), the right most elements of the window do not show up/adjust automatically to the screen size.
Here is a screenshot:
This part is missing (and window is not scrollable from side to side):
Screen Shot 2021-04-23 at 11.34.25 AM
I think this PR should fix it.
Plug-in installed successfully, however unless I don't understand how to use it, it did not change anything. I follow 1-3, but in 4. 1. "The editor will expand to fill the empty space" - last step does not work.
OK, I think I can answer my own question - some of the plug-ins - I believe Outline in particular - were causing trouble with the panes and window view as a total. After deleting the plugins and restarting the app, everything is working well.
