Placement of Panels to the rightmost Position prevents Note Body to auto adjust layout
Hey everyone,
just noticed, whenever I place a panel (note panel, sidebar panel or panel from plugin) to the right most position via "change application layout" the layout inside the Text Body of a note will no longer auto adjust to Window Size changes. Instead the notes gets visually cropped and a horizontal scrollbar appears.
I sometimes like to open 2 apps side by side and after installing the outline plugin, which I wanted to place to the right I suddenly noticed the note being cropped after readjusting the window size. But I also tested the behaviour with other, native panels to the same result.
I'm on Linux, with version 1.6.8
Cheers everyone.
I'm seeing the same on Windows, version 1.5.14
Seeing a similar behavior here like Glint_Eye described, but I don't get a horizontal scrollbar - it feels like the content of the Joplin window is still sized as before, but the right half is just not visible.
Linux, version 1.7.11
