Pannel width adjustment problem
macOS
Joplin 3.0.15 (prod, darwin)
Client ID: 773b04992cfe466f9bdfde852ad8f2e9
Keychain Supported: No
Revision: 598677b
Backup: 1.4.1
CodeMirror Options: 1.1.0
Enhancement: 1.2.1
Freehand Drawing: 2.10.2
Function Plot: 1.0.0
JSheets: 1.1.3
Markmap: 1.7.0
Math Mode: 0.6.2
Outline: 1.5.13
turnToChart: 1.9.3
Wavedrom: 1.0.0
The max width of sidebar and note list pannel are limited, i.e. can't not be adjusted as wider enough to show sufficient information about the note tiltes.
How wide do you need them to be? The panel edges can be dragged to change the size.
animation
My Joplin doesn't behavior like yours.
My Joplin pannel stop at certain point (about 30 chars of width), i.e. if I drag further to the rignt, the handler of the pannel stop moving with mouse.
It seems a problem with plugin "outline".
If I disable it, the problem gone.
