Joplin give me that error when trying to sync torugh Folder system
  • Version PC: 2.11.11 Mobile 2.11.32
  • Sync type: File system (PC to mobile)
  • OS: PC: Windows 10 64 bit Mobile: Android 10
What i did:
1.Set the syncronization settings both on moobile&Pc to "systen folder"
2.on my desktop i created a folder called "Syntching Dekstop"
3. Used syncthing to sync the folder with my Mobile
4. on Mobile: went to Joplin->settings and set the folder route to "Sync Desktop"
What i expected
Syncthing will sync the files from my computer to my mobile. and then Joplin will sync the folder. i will be able to see the notes in the app
What actually
But when i tried to use Jopling to sync the folder i got the foollowing error:
Last error:Fail safe:Sync was interrupted becuse 94% of the data (15 items) is about to be deleted. To ovveride this behavior disable the faile in sync settings. Patn content:(Directory path)
NOTE
i tried to do as he said but the result was that the apped remained empty.
Any idea what to do?
