Joplin 2.7.15 appimage under Linux Mint 20.3,
When I try and print a note, Joplin exits with no message. Log file:
2022/03/18-12:46:39.957 cb9b6 Reusing MANIFEST /home/bert/.config/Joplin/Local Storage/leveldb/MANIFEST-000001
2022/03/18-12:46:39.957 cb9b6 Recovering log #3
2022/03/18-12:46:39.957 cb9b6 Reusing old log /home/bert/.config/Joplin/Local Storage/leveldb/000003.log
Prior versions loaded the window to select a printer. With this version, Joplin just exits.
Are others having this issue? Or would it be something in my system? All other programs print with no problems.
There's an issue on Joplin's GitHub that relates to an upstream bug with Electron where printing causes crashes on Linux.
opened 01:20PM - 31 Oct 21 UTC
bug
desktop
upstream
linux
This morning I upgraded to 2.5.8. I tried to print something, and as soon as I … clicked the print button on the dialogue, Joplin crashed. Now when I reopen Joplin, just opening the print dialog triggers a crash.
## Environment
Joplin 2.5.8 (prod, linux)
Client ID: --
Profile Version: 39
Keychain Supported: No
Revision: dbdb82d
Linux Mint 20.2 x86_64
## Steps to reproduce
1. Go to File, select Print
2. <crash>
## Describe what you expected to happen
Normal print behavior
## Logfile
If anything was displayed in the console, I couldn't see since the application crashes. Trying to attach log.txt but it's saying "is not included in the list"
I have a machine running 2.7.15 on Kubuntu 21.10. With that OS the print dialog appears and it does print, but Joplin just disappears afterwards.
So it seems the problem is Electron. I have a similar problem with 2 other markdown editors: Typora and MarkText.
It would be nice if the Electron team fixed this!
Same environment and problem here too.
I have the same issue with Typora and MarkText. I am sure it has to do with Electron.
sahil
7 April 2022 14:43
#6
I am using same version with appimage on debain based linux distro. The print is working fine here.Though you can export as pdf and print.
Strange. I am using the appimage 2.7.15 it Joplin crashes every time I try to print. And yes, I can get around it by exporting to pdf and then printing.
system
closed
7 May 2022 14:55
#8
