allow grouping tags like folders/notes ie subtags allow grouping tags at least/especially in the tags menu on the left (the one bellow the notes)
if you click on the tag, show all notes witch use that tag allow right click on a tag eg to remove it.
@itge13 I am afraid you will have to better explain what you propose. As far as I can tell, everything is already in place, you may just have to "explore" Joplin a little longer.
I added images.
There is already a topic for this.
The nested tag function was revoked, because some performance impacts. You can finde some topics for nested tags with the search.
