I’ve been using Noteplan on the Mac but being that I’m switching to a different OS soon I wanted to give Joplin another try. I was able to import the directory where Noteplan holds its files and that worked nicely. However, there was one problem: the title of the note was able to be imported into the title field but the tags were not. For example, the beginning of the note will look like this:
# Note title
#notetag
Note Text
Is there a way to import the tags into the tag field that Joplin has? Maybe a script or something?
Thanks in Advance.
Aaron
