Hello
I like to use external links like this on
joplin://x-callback-url/openNote?id=8e5260644185459
on Ubuntu 20.04
What do I need to setup to get x-callbacks for Joplin (2.7.15) it work?
Thanks a lot
Michael
Hello
on Ubuntu 20.04
Thanks a lot
Michael
It should just work. Right click a note, copy external markdown link and paste that link into a browser. It should open joplin to that note.
Unfortunately it does not, a search is started instead of call to joplin.
I am using Joplin as an AppImage, maybe there is something missing in the config?
Maybe i can advice you to install AppImageLauncher that doing a good job with the compatibility beetween your AppImage and your OS.
Thanks for the pointer, I just found out that firefox once asked for the program to use for joplin:// were as chromium simply starts a search.
Some findings
I use under Ubuntu 20.04.3 the non snap version of Chromium since there is no functioning integration for any external keystore tool with snap (same counts for firefox). Obviously I pay for using a keystore with the missing support for x-callbacks. In case someone could fix this I am happy to hear about it.
Michael
