How to use/embed hyperlink?
Using Joplin for the first time. I am unable to use hyperlink.
The hyperlink takes in a URL, gets highlighted in blue, but I am not able to make it clickable. Help appreciated!! Below is a sample zoom link which doesn't redirect to the zoom app automatically like it should have been
You seem to be using the Rich Text (WYSIWYG) editor. There, links can be opened by clicking them while also holding the Ctrl key on the keyboard. This isn't exactly obvious, as the mouse cursor stays the same even when hovering over the link with the Ctrl key pressed, but it does work nevertheless.
