How to downgrade Joplin from 1.0.229 to a previous version?
You need to be more precise in you demand…
To downgrade, you probably need to start uninstalling your current version.
Here 4 ways to Uninstall Software in Linux Mint you can search for your linux distribution on the web.
It depends. The information you gave is insufficient to give you a proper answer. From which version to which version?
If the database versions (schema version) are the same, just replace joplin. If not, you’ll have to export your notes to jex, delete the profile directory, install the old version, and import from jex.
