I know that I can copy the markdown link of a note.
What I would need (to create a very simple collation of a few notes):
select a few notes and copy their links and paste it into a note.
Now, copying the links works fine. But! When I paste them, they are pasted as a single line. This is very impractical. Is there a way to paste them such that every links is on a separate line?
If you use it frequently, I recommend you fully automate it as a macro so that it is only a shortcut away. Use your favorite automation software. Personally I use Keyboard Maestro on Mac.
You select some text, then the macro does "cut", then "replace X by Y in clipboard content" then "paste".
Thank you. I am on Windows, but there is Autohotkey on Windows that I am somewhat familiar with. That will be it for me. If anyone needs it on Windows, here the Autohotkey V1 script that uses the key combination "CAPSLOCK + P" (simultaneously).
The workflow is this:
select the notes
use "copy MD-links" from the tools menu (that puts them onto the clipboard)
instead of CTRL-V, use CAPSLOCK-P to Paste
#SingleInstance Force
CapsLock & p:: ; fix a problem with pasting MD Links in Joplin
txt := Clipboard
txt := StrReplace(txt, ") [", ")`n`n[")
Clipboard := txt
Send, ^v
txt =
return
very easy, indeed. In many cases it does the job. But the result is a list that I cannot convert into a bulleted / numbered list or a list of checkboxes (they all end up in just one bullet/...).
So I'll stick with the macro.
But thank you for the hint with double-clicking a note to open it in an separate windows.
For the record, you can turn the list to a bulleted/numbered one if you do it in the Markdown editor, not in WYSIWYG. But yeah, the macro is definitely going to be faster.
