Evernote import, images are not imported to J
Joplin 2.6.10 (prod, darwin)
Profile Version: 41
Revision: 98fba37
I am attempting to move my notes from EN to J. The problem is that the images inside my EN notes are exported, but not imported into J. The J note is a link? to the image, but no image. This is with the .enex export. I tried the html option, but J will not import. The html file is greyed out in the import dialog box.
Can anyone suggest how I can import my images? tia.
Hi there, welcome to the forum
Could you please check if resources of the images are indeed absent in resources folder in Joplin profile or they are just not displayed correctly?
