Drag and drop reference from Zotero to Joplin does not work
Joplin 1.8.1 (prod, darwin)
Why I can easily drag and drop a reference link from Zotero to Obsidian, but it does not work in Joplin?
Here is the reference to Zotero translator/export feature:
MacOS 11.2.3
