Display "Location" of a note/notebook in note/notebook properties
It would be a great feature to display the "path" of a note or notebook somewhere (status-bar or for notebooks in the properties).
Is this possible to implement?
Best,
Tschortsch
Desktop has the workaround of using the Note Tabs plugin with its Show breadcrumbs option checked under Tools > Options > Note Tabs.
The feature request described in Testing - v1.8.2 - Title Bar Path Format (Minor) would also satisfy your request on desktop if implemented, specifically with how:
The mobile app shows which notebook any note belongs to in the dropdown at the top of the screen.
