Ctrl-G for madness
Hi
The previous version of Ctrl-g was very useful since it would match only the titles. However it seems like the recent upgrade made it to be a super greedy search agent that lists tens or hundreds of search results which makes it just plain useless, given that to be able to try all those search results the user has to
  1. Ctrl-g
  2. Type - > Search
  3. Hit the first (inc=0, inc++) result to see if the result is relevant
  4. If the search result relavant stop
  5. If the search result is not relevant goto 1 and repeat
This process is very overwhelming with even with 10 search results.
I really hope that there will be an option to limit to titles, or make better relavancy calculations.
