Zotero Link Plug In Problem
Joplin 3.3.13 (prod, win32)
Device: win32, 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
Client ID: 618a295481164500aab0f36b48f4bd20
Alternative instance ID: -
Revision: 144ed59
Backup: 1.4.3
Font Size Shortcut: 1.0.0
Freehand Drawing: 3.0.1
Note Link System: 0.8.0
Note list (Preview): 1.1.0
Quick Links: 1.3.2
Templates: 2.4.0
Zotero Link: 2.1.2
I wanted to implement the Zotero plug in, but cannot make it work. After I fixed the problem with legacy mode creating an error, I now have the problem that the "z@" command doesnt fetch anything from zotero. There is also no message from the plug in when I type the command
Plug in for Joplin (v2.1.2) and Zotero are both running, and the port displays the same number (23119).
Am I just stupid? Any Ideas?
Warmhearted thanks
