White Splash on Startup
Joplin 3.0.15 (prod, linux)
Keychain Supported: No
Revision: 598677b
Backup: 1.4.1
Note encryption: 1.1.1
Rich Markdown: 0.13.4
Nextcloud
I have Joplin start application minimize in the tray icon setting enabled, but each time I startup the application I get a full window white splash for 4 to 5 seconds, then the application goes to the tray icon.
I would like to autostart Joplin, but I don't want to get a white window splash on desktop startup.
I would greatly appropriate a fix to this issue, thank you very much!
P.S: Github issue reference GitHub ยท Where software is built
This might a solution to issue:
