Webclipper not working anymore
https://addons.mozilla.org/en-US/firefox/addon/joplin-web-clipper/versions/
click on 1.6.1 - download and install from file. That should do it. And turn off the auto-update in FF :wink:
However, keep in mind that when you upgrade the desktop to 2.x you must upgrade the clipper as well!
YES THANK YOU. when I upgrade I will upgrade everything all together and make proper backups etc. first. (I'm not claming there haven't been improvements, I'm saying I only want to take them on my schedule.)
I found the auto update for extensions in firefox and will turn that off.
Again, thank you.
Is there a new portable app binary going to be released to address this?
Webclipper not working with this version of the portable app.
Joplin 2.0.11 (prod, win32)
Client ID: xxxx
Sync Version: 2
Profile Version: 39
Keychain Supported: No
Revision: 981b1d845
Webclipper version (firefox):
Version
2.1.2
Last Updated
30 June 2021
Yes, it was released 4 days ago.
Apologies for posting, but I can't follow this thread cleanly for the plain answer to this query - When will an updated Firefox web clipper be available in the Firefox extensions library? It's very limiting, to be unable to clip from Firefox.
It's already there. If FF doesn't automatically update it remove it and add it back.
Also make sure you have installed Joplin 2.1.7
Ah the github link! okay thanks, I downloaded the latest from the website, but I think there is a delay before that URL updates. The new version works with the webclipper again.
Shoutout to contributors for the quick turnaround and security efforts!
Joplin 2.1.7
Clipper 2.1.2
