View two parts of the same note at the same time?
Joplin 3.4.10 (prod, win32)
Device: win32, 12th Gen Intel(R) Core(TM) i7-1255U
Client ID: ec1e7c51f1aa4c63b41a9ba5f9d2bf4f
Profile Version: 48
Alternative instance ID: -
Revision: 85585d1
Backup: 1.4.3
Freehand Drawing: 3.1.0
MultiMarkdown Table Tools: 1.2.1
Note Tabs: 1.4.0
Search & Replace: 2.2.0
NB, I also use Arch Linux :slight_smile:
Is there any way to view two parts of the same note at the same time?
Like Split View in ('GASP' :slight_smile: ) Word?
NOT the split between Markdown and Rendered, but in order to see what I wrote in one part of a long note whilst writing another part of the same note?
I do have and love the tabs plugin, so I could make a copy of the note and then flick between the original and copy, which would work but is a bit messy.
Any ideas?
Please?
Oh, and Joplin is So Bloody Fabulous!!!!!!!
You could double click on a note and open it in a new window. If you do it twice, you will have the same note opened in multiple windows, which you can then place next to each other.
Wow - I never knew you could do that!
Thank you @tomasz86 !!!
