How to keep more than one note editor on screen at the same time?
Sometimes I need to read or edit several notes simultaneously, so it's a good way to keep multiple editors on screen. But I haven't found that feature, only can I toggle different notes on sidebar. The effect I expect is like this:
I also try to open multiple joplin windows in WindowsOS level, but that doesn't work.
Jolin 2.8.8
Windows 10
Unfortunately you can’t open two notes side-by-side on Joplin.
In your case you could try VScode plugin. Take a look here.
There's a button for toggling external editing in the note's toolbar. Maybe it's worth to look into if you haven't already.
Cheers!
