In View mode Joplin does not show all line breaks or spaces that show in Edit mode. I have to switch to Edit mode to see the document as I have formatted it.
Enable soft breaks is turned off.
How can I get Joplin to show the properly formatted document in View mode?
Os = Android 10
Joplin Version = 1.1.2
Perhaps you could share a screenshot of this issue?
Although my suspicion is that you have just run into a gotcha with markdown, in this case being that white space is collapsed. I.e multiple newlines become a single newline. If you need your output to have more spacing you can use the html br tag
Example
Some notes that I've been writing.
But I want to have multiple newlines below
<br>
<br>
<br>
And now my notes continue
Thanks for the info. Your sugestion is correct.
I did not realize that I was actually writing Markdown language when editing in Joplin. I am used to using Colornote on Android and Notepad++ on Windows. They are both plain text editors, but I was lookng for something cross platform.
I'm not really sure I want to use Markdown for simple notes. Since I have written a lot of HTML, is should not be too much of a transition. I'll try it for a while and see.
Another way to make linefeeds and spaces render as they do in simple text editors is to use 3 backquotes to mark off the section of your note, or the entire note.
In the Rich Text editor, multiple line breaks are collapsed into one as soon as I re-enter a note.
I think this is the same issue OP described.
For me it makes Joplin harder to use for any sort of note taking.
I understand I can go into markdown editor and use 'br', that's a lot of hassle for a simple line break.
As I missing something here? Is this considered a bug or a feature?
This is for Windows 10, Joplin 1.4.19.
Thanks!
